1996 Plymouth Voyager Brake bleeding
1996 PLYMOUTH VOYAGER
DEMISMAMA
Brakes problem
1996 Plymouth Voyager 6 cyl Front Wheel Drive Automatic
We have replaced the brakes and bled the fluid through but there is still no pressure the brake goes right down to the floor when driving (we tested by going around the block) and now we are unsure of what to do.
May 17, 2009 at 4:30 AM
  • 110,240 POSTS
When you bled the system, did you start from the wheel farthest from the master cylender and work your way to the closest? Also, when you depressed the caliper pistions, did you allow the fluid to be foreced back into the master cylender? If so, you could have damaged the master cylender.
May 25, 2009 at 1:20 PM
