1996 Plymouth Voyager alternator
1996 PLYMOUTH VOYAGER
155,000 MILES • 6 CYL • FWD • AUTOMATIC
NOTWAITIN
im tired of waiting on men in my life to help me repair my vehicle. I have been waiting for 2 weeks on men saying they are going to help me remove and replace my alternator and i dont have money to take it to a mechanic. I am a single mom trying to make ends meet. Im done waiting. can you please direct me? Thankyou!
P.S. Im not affraid of getting my hands dirty....hahaha and im sorry i am not able to donate...this part is already costing me $150.00 that i dont have to spare.
Oct 25, 2008 at 10:13 AM
BMRFIXIT
  • 19,053 POSTS
REMOVAL & INSTALLATION (3.0L)
1.Disconnect negative battery cable. Remove generator drive belt and generator mounting bolts. Remove generator from mounting bracket.
2.Remove B+ terminal nut, field terminal nuts and ground/wire harness hold-down nuts. Remove wire connectors. Remove generator from vehicle.
To install, reverse removal procedure. Tighten fasteners to specification.
REMOVAL & INSTALLATION (3.3L)
1.Disconnect negative battery cable. Remove generator drive belt. Loosen, but DO NOT remove nut on support bracket at exhaust manifold. Remove generator tensioner power steering bracket bolt. Remove tensioner stud nut and tensioner.
2.Remove generator mounting bolts. Remove power steering reservoir from generator mounting bracket. DO NOT remove hoses from reservoir. Remove generator support bracket bolts. Remove intake plenum-to-generator mounting bracket bolt. Remove generator support bracket.
3.Move generator aside, and remove generator wiring. Remove generator. To install, reverse removal procedure.
Need a tool or a tester CHECK IT @
https://www.2carpros.com/affiliate/uid/bmrfixit_1
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 25, 2008 at 10:59 AM
