1996 Plymouth Voyager ABS system
WILLIMAC
Brakes problem
1996 Plymouth Voyager 169000 miles
The ABS light is on and everytime I step on brakes, the door locks open and close, the inside lights start flashing and the door ajar light and alarm turns on and sounds. What is the cause for this?
Willi Mac
Nov 18, 2009 at 3:12 AM
BMRFIXIT
  • 19,053 POSTS
I would suspect a door switch check the side door connector if corroded
BCM data should help need a scanner to access it
Nov 18, 2009 at 10:16 AM
