1996 Plymouth Voyager 1996 Plymouth Voyager stalls and hesi
BABYALEX
  • 1996 PLYMOUTH VOYAGER
  • 6 CYL
  • FWD
  • 135,000 MILES
At first there was a check engine light on for egr valve and random misfire. We did new plugs and wires and egr valve. The codes were erased and never came back.2 weeks later it started to stall when we came to a stop. Also when you start it back up the first little bit of gas you give it, it hesitates then revs up fine. No check engine light. The 2 shops put in, tps, iac, fuel pump, fuel filter, crank sensor, and did a fuel injector cleaning. Still not fixed same symptoms. Also the stalling and hesitation is not all the time just periodicly. Any ideas?
also wanted to add there is no vacuum leaks and a new map sensor has been istalled. Still not fixed.
Tuesday, September 30th, 2008 AT 12:34 PM
LEGITIMATE007
  • 5,121 POSTS
Check ignition module and fuel regulator
Sunday, October 12th, 2008 AT 10:05 PM
BABYALEX
  • 10 POSTS
Fuel pressure regulator is good, ignition modules good. I figured it out though. Wire harness on these has a rub through issue down by the kick down. Every so often a wire to map sensor would ground out.
Sunday, October 12th, 2008 AT 10:57 PM
LEGITIMATE007
  • 5,121 POSTS
Good detective work.
Monday, October 13th, 2008 AT 5:24 AM
