1996 Plymouth Voyager
TYRONEBANKS
  • 1996 PLYMOUTH VOYAGER
  • 6 CYL
  • FWD
  • 175,000 MILES
No spark to spark plugs wont start replaced coil pack replced crank shift sensor still wont start
Friday, October 1st, 2010 AT 1:23 PM
JDL
  • 16,098 POSTS
You need to check for any applicable trouble codes? Did you check for primary voltage at the coil, dark green wire with orange tracer. Same color voltage wire at the fuel injectors. Engine cranking. That voltage comes from the asd relay. I'm not saying the relay is faulty, I'd have to check the relay circuits.
Friday, October 1st, 2010 AT 2:46 PM
