1996 A/C failure
PHILKAT4LIFE
  • 1996 PLYMOUTH VOYAGER
Air Conditioning problem
1996 4 cyl Automatic
Hi, recently I had my A/C charged three times, after about two days I had no more cold air in the car. I had my car checked for leaks and no leaks were found, the only issue was a wrong size belt which has been replaced. What should I do next? Replace the compressor?
Monday, August 18th, 2008 AT 12:18 AM
  • 31,937 POSTS
Hi there,
you should find a mechanic that understands the A/C system, have the pressures tested as this will give the tech enough information to determine if the compressor is still usable or faulty.
Mark (mhpautos)
Monday, August 18th, 2008 AT 12:29 AM
