HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Plymouth
Voyager
Engine
Symptoms
Not Cranking Over
1995 Plymouth Voyager van
FORDPRO1
MEMBER
1995 PLYMOUTH VOYAGER
6 CYL
FWD
AUTOMATIC
113,400 MILES
My van won't start it just keeps turning over. Have put gas in carburator still won't start. Is it fuel pump or tps?
Wednesday, May 20th, 2009 AT 6:43 PM
BMRFIXIT
MECHANIC
Check for spark
suspect timing and crank sensor
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
SPONSORED LINKS
Wednesday, May 20th, 2009 AT 10:17 PM
Please
login
or
register
to post a reply.
Related Engine Not Cranking Over Content
Will Not Crank After Replacing Battery, Starter And...
Just Replaced The Battery The Starter And Fuses All Brand New Parts. It Has Plenty Of Juice You Can Even Hear The Fuel Pump Engage. When You...
Asked by
dmg1022g
1995
PLYMOUTH VOYAGER
GUIDE
Starter Not Working
This guide is designed to help you identify whether the issue with your non-working starter motor is due to an electrical problem or a fault within the starter motor itself...
1999 Plymouth Voyager Only Clicks When I Tried To...
Started My Car And It Died So I Jumped It And It Died 2minutes After I Jumped It And When You Try To Start It The Car Just Clicks
Asked by
larrykatzler
1 ANSWER
1999
PLYMOUTH VOYAGER
Will Not Crank Or Start
We Turn The Key On And The Dash Lights Come On But Will Not Crank And No Headlights. Wont Turn Over Or Anything. It Has A Fuse For Starter...
Asked by
kleggskaa1
1 ANSWER
1 IMAGE
1999
PLYMOUTH VOYAGER
No Crank
It Still Has No Crank Or Fire, I Have Ran A Hott Wire To The Coil Wire(red&green)still No Crank, I Have Changed The Computer Does The...
Asked by
aNTLIVE77489
3 IMAGES
1997
PLYMOUTH VOYAGER
I Went To Start It An It Tried To Turn Over, Then...
My Husband Checked And Cleaned Battery Terminals And Put Them Ban On. The Key Was Not In The Ignition But The Van Wanted To Turn Over...
Asked by
ttp4676
1998
PLYMOUTH VOYAGER
VIEW MORE
SPONSORED LINKS
Battery Replacement Saturn
Starter Replacement
Battery Replacement Toyota
Online car repair manuals
