1995 Plymouth Voyager tail lights
JOEY956
Electrical problem
1995 Plymouth Voyager 6 cyl Front Wheel Drive Automatic 160.00 miles
tail lights won't work checked fuses still won't work ,and wipers stop sometimes?
Jun 19, 2008 at 3:02 AM
JDL
  • 16,098 POSTS
Did you check for voltage and ground at the talilite socket? Turn on the parklites, check the wires going to the taillite socket. I believe the black wire with yellow tracer is voltage and the black wire is ground.
As far as checking fuses, you also have to check that the fuse circuit is hot. No voltage at the fuse and the circuit is dead.
Jun 19, 2008 at 4:25 AM
