1995 Plymouth Voyager starter/coil
167,000 MILES • 6 CYL • FWD • AUTOMATIC
NAPETE1989
where is the coil located on this motor, and where is the solenoid located. the motor will just click when I try to start it the battery is good.
May 29, 2009 at 7:52 AM
BMRFIXIT
  • 19,053 POSTS
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_368.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic2_171.jpg
What you have for engine size ? Try and get a jump suspect bad starter if not cranking ***************************************** need manual CHECK IT @ https://www.2carpros.com/kpages/auto_repair_manuals.htm
May 30, 2009 at 11:39 PM
