Can anyone tell me where to start in replacing the heater core. Do you have to take out the dash? steering wheel?Please help.
Feb 19, 2010 at 10:56 PM
CARADIODOC
✓Experienced Mechanic
Yes, it's very involved. What are the symptoms? If it's lack of heat, there's a simple fix.
caradiodoc
Feb 20, 2010 at 10:54 PM
RONALD E BROWN
MEMBER
It started with no heat ,then one day the heat started in -25 c ,so did the leak, not sure what caused it to free up and leak at the same time, but now it drips from the bottom casing where the core is .It is a must that I have to replace it.
