1995 Plymouth Voyager rear wipers will not turn off
1995 PLYMOUTH VOYAGER
161,000 MILES • 6 CYL • 2WD • AUTOMATIC
VICTORLLL
MEMBER
my rear wipers will not shut off i try change the switch and i unplug the switch but still stays on how do i fix the problem ?
Sep 10, 2010 at 4:12 AM
DOCFIXIT
✓Experienced Mechanic
Hi Most likely the rear wiper module is faulty located in rear door panel. Pull fuse #13 in I/P fuse box should stop until can be repaired.
Hope this helps
Thanks for donate
Sep 10, 2010 at 5:38 AM
VICTORLLL
MEMBER
are you talking about the wiper motor it self?
Sep 10, 2010 at 7:18 AM
DOCFIXIT
No module is seperate from motor inside lift gate
Sep 14, 2010 at 8:07 AM
