1995 Plymouth Voyager need help
DWALL1723
Engine Mechanical problem
1995 Plymouth Voyager 6 cyl Front Wheel Drive Automatic
my voyager is smoking out of the valve pans and will only run for about 15 to 20 minutes then dies and is hard to start back
Dec 28, 2009 at 11:34 PM
  • 110,248 POSTS
How many miles are on the vehicle? If smoke is coming from out of the valve covers, that usually indicates blow by, or bad rings. Let me know the mileage. Also, you may want to do a compression test on the engine to make sure it is within spec.
Jan 4, 2010 at 6:38 AM
