1995 Plymouth Voyager luke warm air in front.but hot air bl
MONTAGUE MARTIN
Heater problem
1995 Plymouth Voyager 6 cyl Two Wheel Drive
i just changed the heater control valve.
when i went to get it the store had 2 options.
one for the front which had a connection for to water lines.and one for the back which had a connection 3 lines.so i bought the one for the front
and got home and the only control valve i found had 3 hoses.well did the exchange put it on and still only luke warm air from the front vents.where is this other valve located? could not find it.the three hoser is right in front of the heater core on the fire wall.
thanks alot
use to be warm
Jan 16, 2009 at 1:23 AM
2CARPRO JACK
  • 11,533 POSTS
the 2 hose valve is for a vehicle without rear heat. The 3 hose is what you need. Be sure both heater hoses for the front heater core are getting hot.if so , you probably have a blend door problem under the dash
Jan 16, 2009 at 8:32 AM
