1995 Plymouth Voyager leaking fluid
1995 PLYMOUTH VOYAGER
15,500 MILES • 6 CYL • FWD • AUTOMATIC
MUTLY
My van is leaking fluid i think it is coming out of where the axle goes into the motor or transmission i think i might have blown a gasket do you know what kind and if that is the problem Thank you Very much
Apr 23, 2008 at 6:55 PM
  • 31,937 POSTS
Hi there,
If the oil is leaking from the drive shaft input of the transmission there is a seal that sits in the out put of the diff housing (where the drive shaft fits in) the shaft must be removed to replace this seal.
Mark (mhpautos)
Apr 23, 2008 at 9:39 PM
