HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Plymouth
Voyager
Climate Control
Heater
Not Working
1995 Plymouth Voyager heatercore
LUCI08
MEMBER
1995 PLYMOUTH VOYAGER
Heater problem
where is the heatercore located. How do I check it
Saturday, November 8th, 2008 AT 2:01 PM
BLACKOP555
MECHANIC
The heater core is located in the air ducts, look for two heater core hoses going through the firewall into the cab, thats where its at.
What would you like to check on it?
SPONSORED LINKS
Saturday, November 8th, 2008 AT 2:38 PM
Please
login
or
register
to post a reply.
Related Heater Not Working Content
1995 Plymouth Voyager Luke Warm Air In Front.but Hot...
Heater Problem 1995 Plymouth Voyager 6 Cyl Two Wheel Drive I Just Changed The Heater Control Valve. When I Went To Get It The Store...
Asked by
montague martin
1 ANSWER
1995
PLYMOUTH VOYAGER
VIDEO
Heater Not Working
Instructional repair video
GUIDE
Heater Not Working
Step 1 - A heater cannot operate unless the engine is full of coolant/antifreeze. If coolant level is low check the system for leaks.
1995 Plymouth Voyager Heater Question
Hello Bob And Ken, I Just Found This Site And I Think It Is Great. I Hope You Can Help Me Out! I Have A 1995 Plymouth Voyager. It...
Asked by
melissa111
1995
PLYMOUTH VOYAGER
1996 Plymouth Voyager Lack Of Heat
Recently The Heater Stopped Heating, Pushing The Slide Bar To Heat Did Not Result In Heat. Taking Off The Pannel Showed An Electrical...
Asked by
Dick Burke
1996
PLYMOUTH VOYAGER
1998 Plymouth Voyager No Heat
Rear Wiper / Int. Rear Wiper, Air Cond. And Recirculate Air Lights All Flash. Temp Selector And Airflow Selector Do Not Function. Fan Blows...
Asked by
mistrd
4 IMAGES
1998
PLYMOUTH VOYAGER
1994 Plymouth Voyager Heater Will Not Get Hot
1994 Plymouth Voyager Mileage: 65,000. Heater Will Not Get Hot. Temperature Gauge Is Normal. Air Is Just Barely Warm. Have Replaced...
Asked by
2CP-Archives
1 ANSWER
1994
PLYMOUTH VOYAGER
VIEW MORE
SPONSORED LINKS
Heater Not Working
How to Replace Damper Door Switch
Blend Door Actuator Replacement
Online car repair manuals
