1995 Plymouth Voyager Headlight adjustment
VUKELICH-6
Electrical problem
1995 Plymouth Voyager 4 cyl Front Wheel Drive Automatic
I changed out my headlight body I guess you would call it. The piece with the lense. Now I need help adjusting the lights.
Dec 26, 2009 at 11:42 AM
BLUELIGHTNIN6
  • 16,542 POSTS
There are adjusting screws at the top and sides of the lights. The screw posts are threaded bolts with a 3mm hex shape end on it and can be adjusted with a socket wrench. The vertical screw post adjusts the light up (counter clockwise) and down (clockwise) and is located in an access hole on the top of the light assembly just to the outside of the headlight center. The horizontal (left/right) adjustment screw post is located on the back of the light assembly towards the car center. Turn the post clockwise to lower the headlight beam and counter clockwise to raise it.
Feb 27, 2010 at 2:20 PM
