1995 Plymouth Voyager Fuel problems
BOND1983
Engine Performance problem
1995 Plymouth Voyager 6 cyl Two Wheel Drive Automatic
My mom and dads voyager had been smelling like it was leaking fuel and i found that the hoses on the fuel filter had been worn and were leaking. I replaced the filter and the hoses but now there is no fuel getting to the engine the pump is good the in jector is good i think there may be a vacuum leak but i have no idea how to check or identify where that would be please help.
Aug 5, 2010 at 6:26 AM
LEGITIMATE007
  • 5,121 POSTS
you will need to cycle it several times (prime it) before the gas gets to the engine, also make sure you did not put the filter backwards( a lot of people do that) and check the fuel pressure regulator to make sure the vacuum hose is connected
Aug 20, 2010 at 9:01 AM
