1995 Plymouth Voyager check gages
1995 PLYMOUTH VOYAGER
CONSCRIPTABYSS
1995 Plymouth Voyager 6 cyl Automatic 143285 miles
My van will not start and the check gages light comes on whenever i try. I am thinking maybe the connecter for the negative wire for my battery is bad. Not sure though.
Jun 3, 2009 at 12:12 AM
JDL
  • 16,098 POSTS
Hello, not sure if your saying the starter won't crank, or the vehicle won't start? If the starter won't crank, make sure the battery has a full charge and the cables are ok.
If it cranks good but won't start, check the basics. Have a helper crank it, while you check for spark at the plugs and injector pulse. Check fuel pressure. Check for troublecodes.
Jun 3, 2009 at 1:33 AM
