1995 Plymouth Voyager charging system
GEORGEGRANTHAM
Electrical problem
1995 Plymouth Voyager 6 cyl Front Wheel Drive Automatic 200k miles
where is the voltage regulated on a this vehical
Oct 7, 2009 at 12:46 PM
JALOPYPAPA
  • 467 POSTS
It doesn't have a conventional voltage regulator. The PCM (computer) regulates the alternator field voltage. I was getting a trouble code for the field circuit open or shorted, and the alternator tested good off the car, but I couldn't find any wiring fault. Soon after, it did it again, and this time the alternator wasn't putting out voltage. The trouble turned out to have been worn brushes in the alternator causing an intermittant failure that set a code.
Oct 7, 2009 at 2:05 PM
