Engine Mechanical problem
1995 Plymouth Voyager Two Wheel Drive Automatic
i replaced the water pump in my 95 voyager 3.0 and now it wont start. I did my best to keep all the pulleys in the same spot, i even marked them. I put it all back together no leaks but no start either. Do i need to adjust the distributor or is there another solution?
Mar 28, 2009 at 2:06 PM
