1995 Plymouth Voyager broken flex plate?
1995 PLYMOUTH VOYAGER
188,000 MILES • 6 CYL • FWD • AUTOMATIC
JALOPYPAPA
  • 467 POSTS
Van was missing under load, now won't run. Shop ran scope showing crank/cam sensors not synchronized, diagnosed broken flex plate or stretched timing chain. Isn't the flex plate more likely? I would think OHV chain pretty short and sturdy, not much chance for slack like a DOHC. Has it even got a tensioner?
Apr 12, 2010 at 5:16 AM
CARADIODOC
  • 34,381 POSTS
Which engine do you have? The timing chain in the 3.3L can't stretch far enough to set a code. A broken flex plate is fairly common. The 3.0L has a timing belt, not a chain. Both signals come from the distributor.
caradiodoc
Apr 12, 2010 at 4:02 PM
JALOPYPAPA
  • 467 POSTS
It's the 3.3. That's what I thought re timing chain. No codes, OBD1 (1995). Any other theories?
Apr 13, 2010 at 2:33 AM
CARADIODOC
  • 34,381 POSTS
First, listen for the hum of the fuel pump for one second when you turn on the ignition switch. If you don't hear it, bang on the bottom of the tank while a helper cranks the engine. The fuel supply system is not monitored so no related codes will be set.
If you hear the pump, check for spark. If it is missing, measure the voltage on the dark green / orange stripe wire on the coil pack, or on either of the small wires on the back of the alternator. If it is missing, suspect the crankshaft position sensor or camshaft position sensor.
caradiodoc
Apr 13, 2010 at 5:03 AM
JALOPYPAPA
  • 467 POSTS
Got fuel, spark. Ignition module, no distributor. Sure seems like it's jumped time, though.
Apr 13, 2010 at 10:44 AM
CARADIODOC
  • 34,381 POSTS
Yup. If you have spark, the cam and crank sensors are working. You might try a squirt of starting fluid on the remote chance the injectors aren't firing. Your comment earlier DO suggest a cracked and turned flex plate.
caradiodoc
Apr 13, 2010 at 8:24 PM
JALOPYPAPA
  • 467 POSTS
It took three weekends, but I got the flexplate out. It was fine. Put it all back together.
Lessons learned:
1. An engine support fixture is worth the money, rather than a jack and block of wood under the oil pan. With only one engine mount still in place at the front end, the engine will rock too much to rely on a jack for support. Definitely a hazard if, as I was, you're working on even a slightly sloped driveway. Would have been far better to work on a level surface.
2. There's too little clearance between the back of the transaxle and the crossmember for maneuvering. Go ahead and shift the crossmember back. Here's how: Tie up the passenger-side end of the steering rack to the exhaust pipe with a piece of wire (the steering linkage will hold up the other end) and unbolt the steering rack from the crossmember. Then remove the driver's-side nut and bolt from the crossmember. On the passenger side, remove the nut and loosen the bolt. Pull the driver's-side end of the crossmember back. The extra work and few inches of space are more than worth it in easing the frustration of getting the transaxle in and out.
3. A proper transmission jack is a must. I rented one, but it was a two-ton model, really too big and just got in the way. I then bought the Harbor Freight 400-pound-rated dual scissors jack for $80, which actually worked better. Be prepared for the fact that a front-wheel-drive transaxle's center of gravity isn't really over the pan, which is the jacking point for most transmission jacks. You may need a floor jack in addition, to support the differential and tilt the transaxle--definitely necessary for the cheap transmission jack, which doesn't tilt side to side.
So that leaves a timing issue of some kind at the other end of the engine, if I can believe the printout I was shown of the cam and crank signals being out of synch with each other. I think I'll seek a second opinion before tearing down the front cover.
Jun 1, 2010 at 4:47 AM
