1995 Plymouth Voyager backup lights fail to work
1995 PLYMOUTH VOYAGER
140,000 MILES • 6 CYL • FWD • AUTOMATIC
SIXONE1974
I have replaced both backup lights, but they fail to work. All other lights work fine. Could it be the PRNDSL switch on the transmission, or grounding? What should I check ? Any suggestions?
Jun 3, 2009 at 7:51 AM
JDL
  • 16,098 POSTS
Hello, I"m not sure of the litre size of your engine? There may be a back-up lamp relay in the power distribution center under the hood, I'd do some testing at the relay.
Jun 3, 2009 at 8:14 AM
SIXONE1974
The engine size is 3.3 L. It is an LE also. This has been an EXCELLENT van. I have owned it since 1998, with about 66000 miles on it then. Changed out the timing chain, radiator, had cracked, and hoses, and new water pump two years ago. Runs like a TOP!
What web site will have a good schematic of the circuit for I can trouble shoot this. I do have a Haynes auto repair manual, but it doesn't go in depth enough.
Thanks for the help
Jun 3, 2009 at 10:22 AM
JDL
  • 16,098 POSTS
https://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
Scroll to almost the bottom of the page. It may be the same diagram that is in your book. Anything that is controlled by a relay, I start testing at the relay.
Jun 4, 2009 at 1:28 AM
