1995 Plymouth Voyager
69BOYZ2000
  • 1995 PLYMOUTH VOYAGER
  • 6 CYL
  • FWD
  • 16,654 MILES
I am not getting any spark to my spark plugs
Tuesday, March 2nd, 2010 AT 5:53 AM
CARADIODOC
  • 34,366 POSTS
Which engine do you have? Have you checked for fuel pressure or injector pulses? You must check for spark AND fuel or you will likely be searching in the wrong circuit.
For an important clue, you can also measure the voltage on the two small wires on the back of the alternator, but they must be measured during engine cranking, not simply with the ignition switch turned on.
Caradiodoc
caradiodoc
Wednesday, March 3rd, 2010 AT 11:14 AM
