1995 Plymouth Voyager
1995 PLYMOUTH VOYAGER
METALGOD
Transmission problem
1995 Plymouth Voyager Front Wheel Drive Automatic
i got my van stuck in the snow so a friend of mine kept putting it in drive then reverse in a rapid motion.then my front wheels stopped moving.nowwhen i move the gear shift i dont here the transmission ingage.i checked the tansmisson fluid i was a little low so i put a couple quarts in.but that was no help.what else could be the problem.and how do i fix any problem u think it could be.any hlp would be helpfull.
Jan 23, 2009 at 6:58 AM
MERLIN2021
  • 17,250 POSTS
Check the CV axles, if a cage in the joint shattered under the strain, it will not move...look for the rubber boots being twited, or split, if they are futher investigation is needed. Put it in gear and see if the axles spin inside but not at the wheels. listen for noises.
Jan 23, 2009 at 7:14 AM
