Get the wheel alignment checked are the tires balanced?
Friday, April 10th, 2009 AT 3:11 AM
CARADIODOC
MECHANIC
If the shimmy goes away over 45 mph and when you let off the gas, suspect worn inner cv joint housings. Most commonly the right one. Holler back if you you don't find any other cause, and you want to check the housing yourself.
