1995 Plymouth Voyager
1995 PLYMOUTH VOYAGER
METALGOD
Transmission problem
1995 Plymouth Voyager Front Wheel Drive Automatic
got van stuck in snow.friend rapidly threw in drive and reverse repetedly.tires stopped moving.no longer here transmisson engage when put in gear.checked tans fluid was low filled.no change.would appreciateany help you could give.i dont know much about tansmissions especialy newwer front wheel drive.
Jan 23, 2009 at 7:07 AM
Sounds like the transmission blew-to find out what's wrong get it pressure tested this will tell you what's going on with it-Inspect shift linkage
Jan 23, 2009 at 7:56 AM
