1994 Plymouth Voyager wont take charge
19,700 MILES • 6 CYL • 2WD • AUTOMATIC
TRCOWGIRL
Hi Am geting ready to install a raadiator now for the second time LOL but The AC hasnt worked sinc ei haveowned the van in 2003
tried to give a rechareg went to auto zone the guy there helped but it would not take the charge.
Had a mechanic check the compressor he said compressor was fine
what would prevent the ac unit form taking a charge? it's awful hot with out it lOL
anyway would like advice or access to a diagram of the ac system to try and pin point parts and knwo what i am dealing with and where each thing is
like the reciever dryer? expanmsion valve is that replacible?
thanx for your help sandy
Jun 4, 2008 at 11:23 AM
  • 31,937 POSTS
Hi there,
Start with having the system vacuumed down and check for any leaks. Start here.
Mark (mhpautos)
Jun 4, 2008 at 11:26 AM
TRCOWGIRL
thnax for response however thisleads to another question but if th elines ownt take a charge how owuld they perform a vaccum test? arent they the same lines?
thanx sandy
Jun 4, 2008 at 11:33 AM
  • 31,937 POSTS
Hi there,
This is done using the A/C standard manifold gauge set, it is attached to the hi & low ports on the A/C and a vacuum pump is connected. This is the standard way of evacuating a system and doing a leak test. If a leak is present the system wont hold a vacuum. To locate the leak the system is partly charged with refrigerant with a dye added. this dye will show up as a stain where the leak is located.
Mark (mhpautos)
Jun 4, 2008 at 11:40 AM
TRCOWGIRL
Thanx for explaining now have to see about getting that done
Jun 4, 2008 at 12:08 PM
