1994 Plymouth Voyager Transmission Leaks
15,600 MILES • 6 CYL • AWD • AUTOMATIC
TINISHAS4
My transmission has a horrorable leak, what seals would I need to replace to correct the leak. Could it be the torque convertor seal and the extenstion seals.thanks,
Nov 3, 2008 at 7:21 AM
  • 110,248 POSTS
Hi:
It really matters where it's leaking from. The most common leak is from the pan itself.
Let me know if you can tell where it's leaking from.
Nov 4, 2008 at 3:03 AM
