how do i replace the serpentine belt or loosen the tensioner?
May 14, 2009 at 5:41 PM
Repair Safety Notice:
This information is for general instructional purposes only. Vehicle repair can be dangerous.
Verify all information, follow manufacturer service procedures, use proper tools and safety equipment,
and consult a qualified repair shop when needed.
JALOPYPAPA
MEMBER
Get a big wrench on the tensioner center nut and pull against the spring with one hand and slip the belt off the nearest pulley. Route the new one the same (should be a decal showing routing in the engine compartment or underside of the hood).
