1994 Plymouth Voyager radio/clock
140,000 MILES • 4 CYL • FWD • AUTOMATIC
MEDIC36
  • 6 POSTS
How do you change the time on the clock?
Nov 3, 2008 at 11:02 AM
  • 110,248 POSTS
Hi:
The procedure may differ based on what radio you have. Regardless, try this.
1) turn the radio on
2) Press the set button
3) Press the select button to change from minutes to hour
4) turn the tuner knob to select minutes and hours
5) When you have the correct time, turn the power off and the job should be done.
Let me know if there is something you don't understand, or if your radio doesn't have the items listed.
Nov 4, 2008 at 2:45 AM
MEDIC36
  • 6 POSTS
thanks for the information. I found out that the radio I have has two small holes next the hour and minute decals. You use a ink pen or small thin object and place in in the holes and push in, which changes the hour or minutes as needed.
Nov 4, 2008 at 9:32 AM
  • 110,248 POSTS
Hi:
I'm glad you got it figured out. I appologize, but I tried to give you as general of information as I could because I wasn't sure of the radio type. I actually gave you the information for my 94 Dakota hoping it was the same. You must have the premium sound system.
Regardless, if you have any questions in the future, let me know and I promise to do a better job.
Nov 4, 2008 at 12:47 PM
