1994 Plymouth Voyager power steering pump bolts
1994 PLYMOUTH VOYAGER
KOVPAPPY
Steering problem
1994 Plymouth Voyager 6 cyl Two Wheel Drive Automatic
the damn bolts seem to have vibrated out, now i got the alternator out and still cant see the pump area, ill get the pump bolts from the junk yard, but how do i line up and what exactly do the power steering pump bolts actually attach to
Mar 3, 2009 at 10:04 AM
  • 110,244 POSTS
Hi:
You may have better access to the pump from under the car. As far as replacing it, there are brackets that it bolt to. Just line up the pump with the brackets and replace the bolts. It can be a pain because of location, but doable.
Mar 22, 2009 at 7:16 AM
