1994 Plymouth Voyager Just quit
180,000 MILES • 6 CYL • FWD • AUTOMATIC
LUBI570
I have a 1994 plymouth voyager that had rough idle before it quit for about 4 months and mechanic said it had a dirty injector. When it quit I took the codes by turning ign. switch3 times, and got a 12,37,55 code back, would you know what is keeping it from starting?
Herb
May 11, 2008 at 10:57 AM
  • 75,988 POSTS
To determine if its a fuel or ignition problem do below then comeback
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light.
Fuel pump/Pressure Regulator and Injector/s checks out-start checking the ignition system-power to coil, coil/s itself,distributor pick-up,control module, Cam and Crankshaft sensors.
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time
May 11, 2008 at 11:57 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:fc045c0607="lubi570"]Computer problem
1994 Plymouth Voyager 6 cyl Front Wheel Drive Automatic 180000 miles
Herb[/quote:fc045c0607]
I believe the code 55 indicates end of codes.
Code 12 indicates - Direct Battery input to PCM disconnected within last 50 ignition key-on cycles. Normal if battery has been disconnected, otherwise check battery power and ground connections.
And Code 37 - Torque converter clutch
solenoid CKT or Trans temp sensor too high or low
OK - The not starting when was the last time you had a tune-up? Cap, Rotor and Plugs?
May 11, 2008 at 12:01 PM
