1994 Plymouth Voyager Im confused About this
1994 PLYMOUTH VOYAGER
209,056 MILES • 6 CYL • FWD • AUTOMATIC
FRANCISCO-805
well my 1994 plymouth grand voyager..when i turn it on it acts like if there is no gas, and i know it only has like 1 gallon or 2.But when i took it to the gas station to fill it all up when i was filling the tank, the gas pump made like a stop like if my gas tank was full and i know its not full, im confused like i think that maybe the tunell where the fuel goes through to get to the tank may be clogged up, or i don't know. It din't do it back then, it bearly started doing it like about a wee ago.
Dec 14, 2008 at 6:40 AM
ZACKMAN
  • 4,202 POSTS
You need to have the EVAP purge canister and solenoid checked out. Your EVAP system is responsible to burn all the fuel fumes/vapor off while the vehicle is in motion. The fuel system is pressurized, you can't add more fuel until some of the pressure is released, and it looks like your solenoid isn't functioning properly and you have fuel vapor filling up the hose.
Dec 14, 2008 at 9:40 AM
