1994 Plymouth Voyager fuses
147,000 MILES • 6 CYL • FWD • AUTOMATIC
WINLAND76
I just replaced the starter and now I keep having the 40 amp fuse blowing after replacing 3 of them in the ignition slot or whatever it's called. I don't why it keeps blowing the same 40 amp fuse that's located in a black box under the hood of my van. Please help.
Sep 27, 2009 at 9:03 AM
BMRFIXIT
  • 19,053 POSTS
It did not happen prior to you replacing the starter !
I would recheck the wiring on the starter relay check and suspect starter
Sep 27, 2009 at 9:31 AM
