1994 Plymouth Voyager fuel pump inside tank is very noisy
PENSUMKEL
  • 1994 PLYMOUTH VOYAGER
  • 6 CYL
  • 120,000 MILES
I would like to replace the fuel pump because it is very noisy. It was replaced 30000 miles ago by previous owner. Is there a template available to show me where to cut through the floor so I can change the pump without dropping the tank?
Monday, June 1st, 2009 AT 2:05 PM
MIKEYDAP
  • 6 POSTS
First, get a Haynes manual on the particular year for that model.
Second, you may have to drop the tank as I did with my 1990 Voyager. Drain gas, NO SMOKING, the fuel pump is not hard to replace. Cost maybe about $100 and pick up extra fuel line and clamps. Also, there may be a separate filter that attaches to the pump itself.
Saturday, June 27th, 2009 AT 10:00 PM
