1994 Plymouth Voyager fuel line removal
154,000 MILES • 6 CYL • FWD • AUTOMATIC
VINKUN
1994 Plymouth Grand Voyager SE, 3.3L V6. I have done all the tests, check fuses, wiring, etc. to determine that I need to replace my fuel pump. In order to do so, I have a Checker/Shucks automotive specialist saying I need a special tool to release the bushing. The tool I got from them does not seem to fit anywhere. Where the bushing is connected, there appears to be a plastic sleeve(?) inside the location this tool is suppose to go(?). Can you reply with a picture of the proper tool I need to do this procedure? Also, do I really have to remove this specific connector in order to drop the tank to remove the pump. The picture I am including is a larger size so you may see it clearly...of course, you may do whatever resizing or whatnot you need to with it.
Mar 15, 2008 at 10:17 AM
BMRFIXIT
  • 19,053 POSTS
If my memory serve me right I think you should have a plastic on the line push it in that should release it
check it out
Mar 15, 2008 at 12:18 PM
