1994 Plymouth Voyager front passenger brake smokin hot
18,000 MILES • 6 CYL • FWD • AUTOMATIC
DEFCON7
Hi folks, I have replaced rotors calipers and shoes on both front disc brakes.And test drove vehicle for a week of normal driveing with no problems. Then just the r f wheel started to get smokin hot! I had noticed before when replacing caliper on that side that pads looked melted,as well as caliper sleeve. I checked for play in hub bearing as a precaution but all is tight and free spinning. Am I missing something obvious? Could it be a clogged brakeline or something like that? Please Help! Thanks, Mike
Aug 19, 2008 at 6:31 PM
SERVICE WRITER
  • 9,123 POSTS
Was the problem there prior to the work?
A collapsed brake hose can cause it as you mentioned. Moisture in the brake fluid can cause a boiling condition that will lock it, but rare.
Aug 19, 2008 at 9:59 PM
