1994 Plymouth Voyager DOESNOT LOCK IN
60,000 MILES • 6 CYL • FWD • AUTOMATIC
MAGED
HI MY TRANSMISSION IS FUNNY , IT WENT 6 MONTHS AGO , AND I HADE IT REPLACED BY ONE FROM JUNK YARD . BUT IT DOES SOMETHING WEIRD , IN THE COLD WEATHER ,WHEN U PUT IT IN REVERSE , IT DOESNOT ENGAGE , AND SOMETIMES IT DOES WHEN U PUT IT ON DRIVE .
NOT SURE IF THE PROBLEM COMES FROM THE CONVERTER OR THE TRANSMISSION ITSELF.
CAN SOME ONE HELP ME WITH THE ANSWER?
Nov 26, 2008 at 9:18 AM
  • 110,248 POSTS
Hi:
The easiest thing is to check the fluid level and condition. Low fluid can cause this or a plugged filter. The ATF is heavier when it's cold. NOTE: Check the fluid with the vehicle hot, running, and in park.
Dec 4, 2008 at 11:05 AM
