1994 Plymouth Voyager DBR II tool for bleeding porportioni
1994 PLYMOUTH VOYAGER
JR50
Brakes problem
1994 Plymouth Voyager 6 cyl Two Wheel Drive Automatic
I rebuilt my rear brakes due to a very leaking brake cylinder. Afterwords I found out that i need a DBR II tool (it may be DRB II - dyslexic) in order to hold the proportional valve spool centered while bleeding. Can anybody tell me if there is a work around for this? Is it a mechanical or electrical tool they're talking about? Where can I get the tool if required?
Mar 31, 2009 at 2:39 PM
CARADIODOC
  • 34,321 POSTS
You only need the DRB2 if you have anti-lock brakes, and if you ran the master cylinder dry.
Here's the procedure I give my students: Leave the caps on the master cylinder. Draining fluid will build up a vacuum that slows fluid flow. It should only take a few minutes to remove and replace the cylinder. If a time-consuming problem comes up AND fluid continues to drip, use a stick between the seat and brake pedal to hold the pedal down about two inches. This will move the seals past the ports in the reservoir and block them, trapping the fluid and preventing entry of air. When you're done replacing a wheel cylinder, all you need to do is remove the stick and one cap on the master cylinder and let it gravity bleed for a minute. When no more bubbles are coming out of the bleeder screw, finger-tighten it, fill the reservoir, then stroke the brake pedal by hand a few times. This will bump any stuck air bubbles into the wheel cylinder. Open the bleeder once more, watch the couple of bubbles come out, tighten it and you're done.
If you did run the master cylinder empty, but the lines still have fluid in them, you can fill the reservoir, then stroke the pedal a few times to work the air out. Slowly push the pedal about 1/4 of the way done and hold it for 5 - 10 seconds. Then let the pedal come back quickly. Do this a number of times until the pedal starts to feel normal. When you push slowly, you push fluid down and air bubbles float back toward the master cylinder. By letting off the pedal quickly, the fluid rushing back up to the master brings air bubbles with it. This works really well when you are just replacing the master cylinder. You never have to bleed at the wheels. (You do need to bench-bleed the new master before installing it).
If you do have anti-lock brakes, you can try refilling the master cylinder and doing the pedal-pumping trick. Don't turn the ignition switch on because most ABS systems use a high pressure pump to store pressurized fluid. This will circulate air throughout the system making bleeding much more difficult. Air in the hydraulic control unit is impossible to bleed out without opening two valves. That's why you need the DRB2. Under "Actuator Tests", it will activate the valves so fluid and air can flow. Without ABS, running the master cylinder dry adds considerably to the time involved in bleeding the system, but no special tools are required.
It must be pointed out that if the master cylinder is more than a few months old, you must NEVER, NEVER, EVER push the brake pedal more than half way to the floor when bleeding. Scale and crud build up in the unused bottom half of the bores. By pressing the pedal to the floor, you run the seals over that crud and rip them. Now you get to replace the master cylinder too. This can also happen when a brake hose pops. Pretend there's a 4" x 4" block of wood under the pedal.
caradiodoc
Apr 1, 2009 at 3:22 AM
JR50
OK, so the mastercylinder did run dry and I have to replace it anyway. I do have the ABS system that I can't bleed without the DBR2 tool. How do I get my hands on the tool...is it electrical? mechanical? both?
I have called a number of tool supply stores with no luck OTC for example didn't have the tool and many had never heard of it. If it is expensive over $100 i'll just pay the dealer. Ideas?
John
Apr 1, 2009 at 11:35 AM
CARADIODOC
  • 34,321 POSTS
You don't have to replace the master cylinder just because it ran dry, only if the seals got ripped.
The DRB2 is a hand-held computer that plugs in under the dash to a blue 6-pin connector behind the fuse box cover. I sold one of mine at an old car show swap meet for $650.00. I have one left because I have a '93 Dynasty and an '88, '89, and '95 Grand Caravan.
The DRB2 works on Chrysler vehicles from 1983 through 1994 with the proper plug-in cartridges. The replacement is the DRB3. It's a $6200.00 kit that will work on all Chrysler products up to 2004 and other brands of cars after 1996 on the emissions-related systems. I have one of these too. The cost of this equipment is one of the reasons repair bills are what they are.
OTC made the DRB2 for Chrylser. They also made the very similar Monitor 4000 for the after market and independent repair shops. I have two of those too, but they don't do anti-lock brake stuff.
If you are near north central Wisconsin, I can borrow you my DRB2 if I can find it.
caradodoc
Apr 1, 2009 at 12:45 PM
JR50
wow! yes is it any wonder car repair costs so much. My beamer computer only cost $135. Well, thank you for your generous offer. I am out in Oregon, so don't go searching for the tool.
John
Apr 1, 2009 at 4:59 PM
