1994 Plymouth Voyager crank sensor
1994 PLYMOUTH VOYAGER
135,000 MILES • 4 CYL • FWD • AUTOMATIC
TIGERIRL929
We are trying to locate the crank sensor because we are not getting any fire out of the coil. Need location of crank sensor with a diagram if possible.
Feb 28, 2009 at 7:27 AM
  • 110,244 POSTS
It is bolted to the engine block on the rear at bellhousing of transmission. I'm sorry but I can't locate a diagram for you.
Mar 2, 2009 at 11:53 AM
