1994 Plymouth Voyager cracked distributor
1994 PLYMOUTH VOYAGER
175,000 MILES • 6 CYL • FWD • AUTOMATIC
LAURIES62
We have a 1994 Grand Voyager that would not start. It made grinding noises so we thought it was a bad starter, but then the grinding stopped and we thought it was a bad timing belt. The mechanic determined that the timing belt is fine but the distributor is cracked - not the distributor cap but the distributor itself is cracked. Waht can cause this?
Mar 22, 2008 at 1:56 PM
MASTERTECHTIM
  • 4,750 POSTS
it can crack from a frozen bushing in the distributor causing it to crack.
Mar 22, 2008 at 2:00 PM
