1994 Plymouth Voyager change starter
1994 PLYMOUTH VOYAGER
180,000 MILES • 6 CYL • FWD • AUTOMATIC
MATTHEWRLAENO
i have a plymouth grand voyager 3.8 v6 and need to change my starter. can i get some help. thanks
Aug 29, 2008 at 2:08 PM
BMRFIXIT
  • 19,053 POSTS
Removal & Installation (3.0L, 3.3L & 3.8L)
Disconnect negative battery cable.
Raise vehicle. Remove 3 bolts from engine/transaxle. Remove wire connector terminal nuts.
Remove connector.
Remove starter from vehicle. To install, reverse removal procedure.
Clean corrosion and dirt from cable and wire terminals before installing to solenoid.
Aug 31, 2008 at 12:32 AM
