1994 Plymouth Voyager breaking drive axels
1994 PLYMOUTH VOYAGER
109,000 MILES • 6 CYL • FWD • AUTOMATIC
HAGGIS
i hav changed tires, struts, passengers drive axel, and 3 times now ive replaced the drivers side in a matter of days. Within a block from the house they are just ripped apart.. what could be causing this. Ive tried 3 drivers side axels in varying price ranges. they were all destroyed. Some1 please tell me what is going on?
Sep 26, 2009 at 9:55 AM
JALOPYPAPA
  • 467 POSTS
Sounds like an engine alignment problem. I'd replace the motor mounts. Make sure the one on the front is correctly oriented in its bracket. The bolt sleeve is longer on one side than on the other; the Haynes manual will show which way it goes.
Oct 1, 2009 at 10:12 PM
