1994 Plymouth Voyager belt keeps coming off
160,000 MILES • 6 CYL • FWD • AUTOMATIC
BIGR2645
I have been having a problem with the serptine belt coming off when it rains. I have replace the water pump power steering pump and the tensioner, and the belt, the belt runs true untill it gets wet and then it comes off. I am at a lost on what could be causing this . HELP
Randy
Dec 27, 2007 at 6:59 AM
BLACKOP555
  • 10,386 POSTS
have you tried a new belt? the old one may be stretched out to far, try some belt dressing.
Dec 27, 2007 at 10:33 AM
BIGR2645
[quote:b049650ba3="blackop555"]have you tried a new belt? the old one may be stretched out to far, try some belt dressing.[/quote:b049650ba3]
Yea I have probably put on three or four belts this year and I am using the best belt I can buy also tried different types, Last night I encased the whole bottom side in rubber just to keep the rain out.
Dec 27, 2007 at 11:55 PM
BLACKOP555
  • 10,386 POSTS
next thing to do is take off the belt and manually turn each pulley and see if they are all spinning straight.
after research heres what i found
TSB #070294A -- SERPENTINE BELT COMES OFF PULLEYS. *TW (NHTSA ID #37792, DECEMBER 01 1994)
TSB #070394A -- SERPENTINE BELT COMES OFF PULLEYS. *TW (NHTSA ID #39005, DECEMBER 01 1994)
i guess there is a technical service bulliten out for your modle with the belt coming off the pulleys.
call up your dealer and ask them about it.
Dec 28, 2007 at 1:03 AM
