1994 Plymouth Voyager
BOBMARTINEZ
  • 1994 PLYMOUTH VOYAGER
  • 6 CYL
  • 67,000 MILES
High pitch noise coming from engine area;decreased mpg from by 12-15mpg;had major tune-up, oil change, water pump, timing belt, oxygen sensor done;still have problem only have noise when car is moving;the repairs I did increased mpg by 5mpg but still have noise and problem; I need help in diagnosing what is causing this noise and poor performance?
Monday, April 27th, 2009 AT 1:17 PM
CARADIODOC
  • 33,916 POSTS
Squealing axle seal. My van has been doing the same thing for months. Use a can of spray lubricant with an extension wand to spray behind the inner cv joint housing. You're trying to get the lube onto the inner shaft of the joint which is hidden by the joint housing. At the dealership, I used Mopar Spray White Lube. It lasts the longest; up to two days, but the noise will come back. The only cure is a new seal. You can also spray Mopar Rust Penetrant in there but it doesn't last much more than a few minutes. At least that's enough to prove what the problem is. WD-40 might work too.
Caradiodoc
Wednesday, April 29th, 2009 AT 5:20 AM
