I have a 1994 Plymouth Voyager with 195,000 miles. It has acquired a problem that I can not figure out. It will be running fine and then it will start kicking and bucking and runs really lean. It will not rev up when you hold the throttle to the floor. Then it dies. I have replaced the fuel pump, fuel filter, and the plugs and wires. The strangest part was it ran fine for 2 days after I replaced all of these things then it started doing it again.
Mar 29, 2006 at 4:02 AM
