I have recently incountered a pretty bad oil leak on my 1993 plymouth voyager. Like one hour of driving on the freeway and i am out of oil and a knockin has started and it has 145,600 miles on it i replaced valve cover gaskets, oil pan gasket and i now have the whole rear side opened up thinking it was the front crank shaft seal but upon inspecting the seal it seems to be ok . But when i removed the timing belt cover the is oil pretty much all overbut i cant pin point where the leak is. could help me out with what other seals or gaskets i should check and replace while i have that opened up.Also the oil seems to be leaking above the crank shaft and a little to the right of the crank shaft towards the radator side.If you have any suggestions that would be great thank you very much
Mar 12, 2006 at 8:56 AM
