Brakes problem
1993 Plymouth Voyager 6 cyl Two Wheel Drive Automatic
my brake peddle has minimal pressure until i reach the floor while driving. when i get to th floor it seems that i have good brakes, but it is sudden. all 4 tires will lock if i want to do so. i have no leaks, have bled the brakes, and have new pads/shoes. when i pump the brakes, while the vehicle is off, i get some pressure in the peddle, but it does not become firm. when i let the brakes rest for 10 seconds and repump the peddle i realize i have lost all the pressure that i had pumped into the system. i am confused if it could be more air in the lines, a bad brake booster or perhaps my master cylinder. also, how could i check these components without just replacing the parts at random?
Jan 26, 2009 at 10:29 PM
