1993 Plymouth Voyager Heater/ AC vents move
1993 PLYMOUTH VOYAGER
198,000 MILES • 6 CYL • 2WD • AUTOMATIC
CRESSIN
On my 1993 Grand Voyager the heating and ac vents move from the vent position to the defroster position when you are going up a grade in overdrive. They will return if you let off the gas or downshift. I also have a 1992 that does this and a 1990 that does not. The annoying part is the vents make a high pitched whine when they return to the proper position. I realize the 1990 has a different heater control and air package unit then the 1992 and '93. They have done this since I purchased them (used and much less mileage). The dealer tells me it could be by design (I find that hard to believe) or it could be a bad diverter valve in the vacuum system. I have put heater cores in all of these vehicle and gone over every hose and fitting for leaks that I can find. I am not really worried about the '92 as it is entering retirement. The noise in the '93 is getting on my nerves. The '93 has a 3.3 liter in it and runs fantastic. It also has antilock brakes and does not use a brake vacuum booster so if it has a diverter valve I don't know where they hid it and my parts dealer cannot find a listing for one either. Is there any solution to this or have you heard of this before? Thanks for any help you can give, Don
Aug 15, 2009 at 9:02 AM
  • 110,244 POSTS
Hi:
The vents are atuated by vacuum and when the vehicle is under a load, vacuum drops in the intake. If there are no leaks, the drop doesn't change anything. However if there is a leak, it will chance the direction of the air flow.
I realize you have checked everything, but I'm confident that you are looking for a vacuum leak. It is most likely under the dash, the control unit, or it could be a leak under the hood from the supply hose.
Aug 15, 2009 at 5:04 PM
