1993 Plymouth Voyager fuel pump reset swch
47,000 MILES • 4 CYL • 2WD • AUTOMATIC
BRONZETIGER
Dear sirs,
Hope you can help me. My Van turns over fine but the engine does not catch I do not hear the fuel pump running. Isn't there a fuel pump reset switch somewhere on it? I cannot find mnetion in the manual. Thanks in advance for your help
Apr 29, 2008 at 9:50 AM
BMRFIXIT
  • 19,053 POSTS
check fuses and relays
check fuel pressure
no pressure
check and replace fuel pump
no reset for the fuel pump
Apr 29, 2008 at 1:47 PM
WENDELL MCNEAL
[quote:56d04cb9af="Bronzetiger"]Electrical problem
1993 Plymouth Voyager 4 cyl Two Wheel Drive Automatic 47000 miles
Dear sirs,
Hope you can help me. My Van turns over fine but the engine does not catch I do not hear the fuel pump running. Isn't there a fuel pump reset switch somewhere on it? I cannot find mnetion in the manual. Thanks in advance for your help[/quote:56d04cb9af]
Jun 9, 2008 at 1:28 AM
BMRFIXIT
  • 19,053 POSTS
sorry no reset switch on this vehicle
you need to check fuses and relays
check fuel pump
and fuel pressure
Jun 9, 2008 at 9:53 AM
